Stupid question does the mk 4 have a pcv valve? And if so where is it located? Been looking into what might be causing me to burn about 1l of oil every 1000miles in my 2002 1.2 which I assume is the azq engine, and I have been hearing on many sites check the pcv valve as it is a cheap part to replace, then check do a compression test to check the piston rings and valves (I will be doing that soon).
