33754k
159
Manchester
Has anyone got any pics/ guide on removing the pollen filter cover- Ive got the 2 screws out after a bit of effort, but not sure what to do now (trying to fix a leak into the rear passenger footwells)
Cupra 180 03 plate
it you got a leak in the rear passenger footwell , the water will most likely become from one of the doors seal on the passenger rear door , so there is no need to take the pollon filter cover off as if it was leaking the frint passenger footwell would be like a swimming pool , there is a few topics on this so why not carry out a search .
Cheers Kenny
Kenny is right... if your leak is in the rear passenger footwell it's the door seals you need to worry about, not the pollen filter.
If the front passenger footwell leaks, then you need to worry about the pollen filter.
had a leak on drivers side front door into foot well,turned out it was leaking from under the speaker! easy repair in laymens terms.1 remove door pannel,2 remove the 10mm bolts holding the winder mech pannel on,3 reseal with silicone sealer,rebuild!solved my prob
hey
i cant seem to find my leak... its in the driver side front and rear footwell... can anyone please guide:lol: :-o
ok, so my perception is that the water is leaking from the drivers side door into the front drivers side footwell and then the water is moving its way into the rear footwell. This is a common problem with the front drivers door seals. You will need to get the door seal checked or changed. if you do a searchy there are instructions on how to fix this.
