bagslife86
Hi all, performace wise, i intend to do to my 2001 LC the following..
turbo back jetex system (decat)
cold air induction
007p DV
THS TIP
REVO stage 2 or equivelant
4 bar FPR
costing around £1000- hopefully less!
just while i'm here, i also intend to-
lower it 45mm on springs and shocks
front strut brace
rear ARB
LCR splitter
uprated dogbone and top-mounts
the excitement!!
anyway, as per title, i was wondering what power output i would see from these performance modifications. maybe 235bhp?? and torque?
also 0-60 in how long?? im hoping sub 7 seconds easily...
any comments welcome!!
cheers
You should see cerca 230-240bhp and 260-270lb/ft from stage 2. But you will need a fmic to get those numbers though.
i thought a FMIC was only really needed on a big turbo conversion i.e if you were wanting to push maybe 280bhp??
The front mount will help maintain the power at high revs and also with hard driving or if the air temp rises.
I noticed a drop in performance when ambient temp rose much above 15 degree, and the LCR has 2 side mounts.
You wont get much increase in power with a front mount,although the torque may increase by a bit.Its a mod which helps get the best out of all the other mods youve done if that makes sense.
0-62
any ideas on a 0-60 time??
Your going to be looking at slightly less than a standard LCR for the sprint. Wouldn't bother spending the money on the 4 bar FPR personally. Would spend the money on a FMIC for more reliable top end. mine is running a reliable 233 bhp with 237 shown on a cold day, and it is noticeable that the top end dulls when the engine gets too warm.
