RobboR
51
I received my software and cable today, ebay jobby i know!
everything was going so well, got it installed changed ports etc but when i selected the port i wanted and clicked test the application just seemed to close
any ideas this is doing my head in
its an OBDII cable USB connection
Probably just a conflict in ports causing VAG to shut down.
Go into your device manager and find the USB VAG controller device, double click it and choose a port thats not used by the serials etc.
Then open VAG and goto setting and select same port as you have chosen in device mgr for your VAG controller.
HTH
It was the laptop that was the problem. i went round my mates and used his no problem. everything was so easy. got the cable and software from ebay £15 did the job.
I have an engine temp sensor too high! whatever that is. off i goto research it!
"""got the cable and software from ebay £15 did the job""" ... can you recall the sellers name on ebay who you got the cable and software off? ... I would'nt mind buying the kit myself ... cheers RobboR
Hoggy he was called lonelec and the item is called VW AUDI SEAT SKODA DIAGNOSTIC USB CABLE VAG-COM 409.1
