probs with vag com, cant read from controller 01 Engine
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
I can't seem to get an engine reading from my vag com. When I try to read controller number 01 (engine) it scans and says controller not found. I can read controller number 03 (ABS brakes) which reads fine and a few others but not the Engine one which is obviously the one I want to mainly use.
Any ideas??
Using version 303 of the software
Santos_V
It could be the cable itself thats causing the problem. Could you connect before or is this your first time trying to connect?
Uwe@Ross-Tech
392
www.Ross-Tech.com
What kind of interface?
What version of VAG-COM?
What kind of PC?
Not paricularly strange that it reads some modules but not other's if it's a cheap interface..:)
Of course, there could be other reasons too, such as a wiring problem on the W line between the instrument cluster and the ECU.
-Uwe-
Jonzy
duff cable, identical problems to what I suffered with a cable from the same seller!
seatstu
209
have you tried disconnecting the battery for a few minutes I had problems getting into 46 central conv. tried this and now it works.
