Quick Climate Control Question
timix
Hi all, plugged into vag-com earlier trying to test the climate contol as it seems to do nothing (air-con wise) but all I get is a message saying "too many communications errors to continue"
This is the only time it happens, can log onto all other control modules fine :confused:
I am using a £8 ebay usb lead with vag light, is this the problem?
Feb 26, 2009
5,275
Wolverhampton
There are a couple of modules that do seem to be consistently difficult to contact, and the USB leads do make it that much harder.
My only suggestion is to keep trying, you might get through to it eventually. Or use the onboard climate control fault diagnosis, that can be accessed through the front panel.
