raceland coilovers noob question
Radge-Aha
70
first time iv fitted coilovers so go easy lol..my question is ,on the rear ones does the hight adjuster that comes with the kit sit on the bottom of the spring or does it go on top of the spring? ..just want to make sure of things before i start doing the job tomorrow..thx
The adjuster goes on the bottom, with the little brass bit clamped underneath to keep them from moving.
The creaking will be because the springs have not been dyno tested as rigorously as more expensive models, so they have a lot of adjustment to do.
You can take the rear cups off but be sure the springs are sitting flat against the bottom before you drop the car or you can strip the threads from the other half of the cup and then you cant get the adjusters back on.
