See here in a german forum: https://www.seat-leon.de/forum/thre...halter-incl-ch-lh.111145/page-11#post-2378461
Hi Adamsm, sorry what for a model is your car?
Is it a facelift? Which year of construction?
The sensor 5Q0955559A was installed in the pre-facelift models.
It probably won't work correctly with a facelift model, but I don't know for sure.
Just to make this clear, the interior mirror has nothing to do with the sensor, these are two different construction sites.
Here you can find informations regarding retrofitting interior mirrors: https://forums.seatcupra.net/index.php?posts/4822845
As there isn't a screenshot record (just text) on here of how to go about activating auto lights on a Facelift, I thought I would post up screenshots of the OBD11 method which make make it a bit clearer for those that haven't already carried out the mod.
Obviously you need to fit the modified sensor and auto light switch beforehand.
Fire up OBD11 and go to 09 Central Electronics - Adaptations, now follow the next 3 pictures (check that you have the same values as those marked with an X)
Now go to 5F Infotainment and follow the next 2 pictures (check that you have the same values as those marked with an X)
Yes I have them there still not working. They were working fine before I made the adaptions to activate the automatic lights as per Jim's instructions.You have to have your stalk on 1 click for them to be in automatic mode. Just make sure you've done that.
Sent from my SM-G975F using Tapatalk
Yes it is set to comfort data bus. Also noticed the leaving home lights don't turn on.Check this setting:
Car_Function_List_BAP_Gen2
wiper_comfort_0x0C_msg_bus: set to -> Comfort data bus
see youre last picture
I ended up turning this setting off and then back on. When I went into the infotainment screen under wipers there was the option to turn them on for rain sensing which wasnt there before so can confirm that it's all working now bar leaving home lights. Thanks for the help guys and sorry Jim your guide was spot on. Just me being a noob.Check this setting:
Hey there would you mind telling me where to buy the light sensor and switch
Hello
Appreciate it man which model is yours because mine is the 2019 so I don't know if yours will work or if I need to search for another versionI used a VW polo mk5 6c switch. I got mine from Ebay. I'm sure there are more on there if you search.
The sensor I got from the below. I'm sure it is probably cheaper elsewhere.
https://m.onlinecarparts.co.uk/metzger-8715254.html
Also do you have a link for the light sensor and switch because that's what I'm looking forAppreciate it man which model is yours because mine is the 2019 so I don't know if yours will work or if I need to search for another version![]()
Also
