Range display issues
SueFR
Doncaster
Mar 16, 2015
237
19
Doncaster
Hey,
not sure why this happens or if anyone has had it before.
this is second time it has happened to me, the range display isn’t showing correctly. Iv just filled up and it’s only showing 300, usually shows 550-600
last time it happened it corrected its self on the next fill up.
Anyone had this or know why it happens?
RADIOTWO
489
94
North Derbyshire
Hey,
sounds like a sender unit problem
Rusty2k
710
133
I doubt there is anything wrong at all.
The range is calculated on short term fuel consumption and fuel level not long term. So if you have gone through a patch of bad fuel consumption immediately before filling up (flooring it, town driving, crawling in a traffic tam or sitting idling, etc.) then that is what the range will be based on after you've filled up. Parking on a hill will produce the same effect as the tank has a float sensor for the level.
If either of those are the case you should see the range increasing as you return to your normal driving pattern.
As you've only experienced it twice in the space of a year I suspect you are just seeing quirks from how the range is calculated rather than evidence of a problem.
Reactions: 300bhpdaily
SueFR
Doncaster
Mar 16, 2015
237
19
Doncaster
I never said a time scale? But yes that’s what I noticed last time eventually it started going up again but did take for another car fill up for it to take full affect.
thank you 😊
Rusty2k
710
133
No, but you mentioned you'd been told it might be a sender issue the last time it happened so I searched for posts that you'd used the word 'range' in before to and found your previous thread from Sep '21 and read through that... I was rounding up from 11 months to a year! 🤓 😂
SueFR
Doncaster
Mar 16, 2015
237
19
Doncaster
Hahaha check you out. Mr detective!
Rusty2k
710
133
Haha to be fair I searched back through my own posts too as I knew I'd answered this before but couldn't remember who had asked it...
Turns out it was someone else a couple of years ago..
andylong
489
I know it's a bit necroposty, but I was looking at my MFD the other day because average mpg seemed weird...long story short...
Maybe you hit the ok button on the steering wheel.
You can change the way the MFD shows mpg and when it resets range amongst other things.
My mk2 has 2 memories for AVG mpg, and 2 methods of resetting range.
The MK3 has 3 methods of resetting range, on fill up, manually and after many 1000s of miles.
SueFR
Doncaster
Mar 16, 2015
237
19
Doncaster
Hey, nah wasn’t that. But all sorted now ☺️
Rusty2k
710
133
Resetting the short or long range trip computer settings does not affect the range calculation on the Mk2 Leon.
SueFR
Doncaster
Mar 16, 2015
237
19
Doncaster
What was it?
First time it happened it corrected its self after filling up again but second time it happened last year it’s taken a lot of steady driving to get it to what it was and I believe it only messed up as I had some work done on my car and something must have been affected in having work done? Anyway it’s now back to how it should be
