ratteling back end
gazb1409
hi could anybody help me find what it is on the back of my leon tdi 150 its making a ratteling noise when i go over bumps and sometimes its quiet a load banging noise i have been under the car as it sounds like something is loose but cannot find anything also it seems to not do it with the brakes on which is a little worrieing i just want to know if any1 as had this same problem with the mk1
jasonhanson88
Your rear shockers are probably shot.
Im in the process of gettin mine changed,
I will let you know if it stops it.
gazb1409
no its defo comin from the bach drivers side some where i know 1 of the bushs sqeeks on the back but its not that thats doin the rattling sound i will try the shocks could you let me know how you get on please jason thanks guys always a great help comin on here many thanks again
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
sounds like the bottom connection on the rear shocks.. mine are shot too! need to replace them soon :)
gazb1409
problem solved turns out the caliper carrier was'nt put back on properly when it went in for rear disks and pads so it wont be goin back
Hudds
75
Huddersfield
I had a problem just like this, took me months to work out, and it was actually the lock on the boot, the spring had come loose inside the lock, could be worth a look. Or as I did, get someone to sit in your boot and pull it tight!
