rear wiper doesnt wipe properly
denispearl
112
Hey again guys. So there is another problem ( boring I know, sorry.
This time rear wiper blad doesnt wipe all the surface but middle part only. I mean it doesnt wipe where it supposed to do, as wiper doesnt touch the glass in many times (ends of wiper blade).It is bosch rear blade (new)
Any suggestions?
Jan 11, 2005
680
Barnsley
Bend it some more :lol: When you pull the arm back the wiper should curve so that the ends are closest to the glass. Just twist the ends round a bit to make them curve round more
Jan 11, 2005
680
Barnsley
They can bend a lot if they are the flat aero type, almost to the point where the two ends touch. I've done it to all my wipers to adjust the pressure on the glass for an even wipe
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
It is possible that the spring in the ARM is stuffed and can't provide enough pressure to the blade.
lift it up about 6" put ya hand on the glass to catch it and see if it springs back properly with some force
if not pull it back til it rests and grease/spray up the arm's pivot point as it's usually corroded and full of crap in the there
then stick a new blade on for £3 or so it won't hurt after all
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
you might have tightened the nut too much...would cause the wiper to put less pressure on outer edges and not sweep properly
try loosening a tad...if no avail then switch to aero wiper :)
