Exactly what i have planned, i just bought a 4 awg amp wiring kit as it worked out cheaper than buying decent power cables.
Looks good fair play.
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
-snip-
I'm also experimenting running twin Bailey dump valves, recirculation DV30 on the hotside and atmospheric DV26 on the coldside ... works great, no fault codes and sounds great! Time will tell how successful it is but initially no problems at all.![]()
http://i112.photobucket.com/albums/n191/robd67/bov1.jpg
Mine is already tucked out the way (as you can see in this pic),
http://i112.photobucket.com/albums/n191/robd67/0804.jpg
Doing the battery shouldn't be difficult, I've ordered an alloy battery tray which can be drilled and bolted to the boot floor, will use some JB Weld on it too to make sure it's secured well. The hold-down is part of the tray so it will be exactly what I need.
http://stores.ebay.co.uk/alloy-raci..._W0QQcolZ4QQdirZ1QQfsubZ9610775QQftidZ2QQtZkm
I've ordered 5m of red 4AWG and 1m of black 4AWG cable, terminals and the tray already. Once new year hols are out the way next week I'll get on with it!
Mine is tucked down the side of the ABS unit, with the main red cable extended to the distribution block that the battery cable comes back to.
I think you'll blow the 80 amp fuse to bits at some point. The original +/ve connection to the starter motor isnt fused.
