Removing LCR Rocker cover
Apr 24, 2007
985
W. yorkshire
Got a replacement cover to get either polished or painted yesterday.
Now wondering is simple enough removing it is there anything i need to look out for?
Apr 24, 2007
985
W. yorkshire
yeah im gona check the gasket but wouldn't have thought the gasket would be too bad as its only 2 1/2 years old.
does anyone know where i can get the torque pattern from? other than a haynes manual (which i cant seem to get hold of)
Apr 24, 2007
985
W. yorkshire
its strange that they dont as its not a million miles form others that they will already have (golf, a3, tt) plus they do them for just about everything else you can possibly think of
v-g
is an alien.
Mar 10, 2004
938
Nowhere near, i.e. Norway.
I would assume ELSAWin could tell the correct torque settings.
I've only used it for torque settings on suspension parts for my LC. Haven't looked around for anything else.
My copy of ELSAWin don't work at the moment, I think Pat's (Fester's) does.
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
removal - Loosen the nuts -arrows- beginning with the outer ones in diagonal sequence, and ending with the inner.
‒ Remove the nuts -arrows-and remove the cylinder head cover.
refitting - First tighten the inner nuts and then the outer nuts of the cylinder head cover, in diagonal sequence to 10 Nm.
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
fester you maybe a short arse and have to use blocks of wood to get to the pedals but you know a bit dont you? lol
anyone know where i can get a copy of elsawin from?
cheers
Mar 26, 2007
2,019
S.Wales
i would def. get a new gasket!!!
i refurbed the engine on my old escort and the gasket cost about 12 quid!
assumming the leon has a gasket made of cork theres a good chance you could break it taking the rocker cover off.
Apr 24, 2007
985
W. yorkshire
does anyone know if there are differnt coverd to different bam engine?
as i've got an 03 s3 one but it looks different to my 04 LCR
