Removing the inner metal door card
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
mole grips will get them out definatly! they do have blue lock tight on them so maybe the 1 you cant get out has got more on and has seiesed in a bit! wouldnt drill it out as it will take ages on a cordless drill and will eat about 5 drill bits! and you would also have to re tap the thread in the catch unless you have a new 1?
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
sorted mate, mole grips and a flat head in in did it. Also got a new door card on but dont have door pins anymore lol
Rosco906
1,445
Burntisland, Scotland
guinness u did what i did.
Broke the clip which holds the lock carrier on
Still havnt fixed mine. Not had time to go to scrappy's
what side did u break?
I broke drivers.
I was thinking about taking it off and maybe fire a weld on it. doubt it'l work but havnt had time recently.
Did u do the pic's for me also?
rashcupra
Oct 15, 2006
6,517
crawley
that plastic bit just locates the catch in position to get the bolts in not REALLY needed just more fiddly when removing/replacing it
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
mine didnt break, it more just pushed off so I put it back on lol (dont undo the screw 2 much lol). Im off to the breakers again tomorow or the day after for some blank plated for the door pins and some screws lol.
Rosco906
1,445
yeah but when u tighten it up, the lock itself can still come out
unless your on about a different bit. Im on about the bit i broke ages ago lol which u said i'd broke it lol
I broke the bit that holds the lock carrier in, the bit that pings off if u unscrew it to far
Fancy getting me one lol
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
o and rash wehre on about the metal ring around where the lock barrel goes in, if you nock it when yo put it in and the screw is a fraction too loose it breaks :(. Dont understand what bit your on about really, but if I see one I will be sure to steel it for u matey. Iv got a spare lock mechanism, will take a picture later and see if its the bit your on about.
Rosco906
1,445
its the bit that holds the lock in, u know how u unscrew the small torx, that bit which has the clip on it is the one i broke.
i unscrewed it to much and it fell off.
Nab me one if u can matey
rashcupra
Oct 15, 2006
6,517
crawley
you only undo the handle (gold 25 torx) untill it gives off a little resistance then the barrel will pull straight out. make sure you have the handle in open position when losening
I WILL MAKE A VIDEO! AS ALOT OF PEEPS NEED 1 I THINK!
and the title will be
*HOW NOT TO FCUK A DOOR* :lol: :hide:
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
yer lol. nah it wasnt that mate the cover for the barrel I bought was f**cked so it didnt go in properly hence I batterd it in. I think the handle is a T15 as well mate. Also see why you do the handle now so that it keeps attached to the platic bit lol
Rosco906
1,445
mint lol
got pic's of rhe car yet?
also did u get ma pic's or did u forget?
Just need to get car ready for jan ifi sell it again lol
Close 2 buying my own place
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
think thats what you mean mate
(a broken 1 I stole to compare and work out how to fix mine), I can get one of those on friday for u if you want matey and post it to u :p
Rosco906
1,445
err, i duno if thats it.
i'l take 1 anyway just incase it is.
Just looking to see where the small torx bolt goes back into to hold the lock in.
If thats what holds the lock bit in then iys what i need
rashcupra
Oct 15, 2006
6,517
crawley
you need the cage handle mechanism on the inside of the door skin that HOLDS the handle in position and operates the leaver motion
the pic that guiness has posted up is what i think you needed rosco as the gold screw is in the bottom right of the pic
is the one in the pic guiness the broken 1 or your new 1?
