rich3001
137
I recently had a HID bulb blow and have been trying to find a replacement. The bulbs are H4-3 Hi/Low beam. I can find the bulbs but the do not have the same connector for the wires that switch between high and low. Is the only option to replace the relay harness and wires or can i cut the wires and fit a connector block? I had only had the kit in a few days when the bulb went and there is no warrenty on them [:@]. Does any one know any places i might be able to get a replacement? Any help would be appreciated
I wouldn't use a connector block between the bulbs and the ballasts - you are playing with appx 20,000 volts there.
Next time you are shopping for HID's - make sure they offer spare bulbs on their website.
Ebay item:- 370295569146
.G.
I think i will just buy the new wiring and bulbs, seems the safer and easier option. Thanks
