Replacement hoses
TJenkos
213
Derby
Hey all,
Wondering if you could help. Im after some replacement hoses, but am not sure of their names!
Both hoses go from the engine to the TIP. One goes between the engine and dump valve and the other to a plastic filter looking thing?
Theyre both the larger hoses linked to the TIP..
Thanks in advance!
Tom
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
i think he means the 8mm vac hose going to the N75.
just buy some 8mm vac hose off ebay and cut it to size
TJenkos
213
Derby
Hey,
No the hoses are the larger ones. The base of the dump valve goes into the TIP, then the side goes onto a hose which goes to the engine. I dont mean the small piping on top..
Sorry I cant be of much more info but as I say im not sure myself!
Tom
TJenkos
213
Derby
Heres a picture I found on here. Ive put a couple of arrows on the buggers. I assume theyre upper boost hoses - but cant find the same on Forges website, Ill try ringing tomorrow..
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Try putting an add up in the wanted section...
Ive got the one that goes from the dv to the charge pipe...pm me.
