*RESOLVED* Fault Code(s) 0.4 Bar Max Boost = Constant Limp Mode!
Pyro
Small boost leak won't cause it mate I'd would imagine if there's a leak it'll be quite big get the logs done logging your boost and maf and go from there :)
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
mo can you run some maf logs on vagcom. new mafs are also known to be faulty before they even get fitted to a car.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Not sure I agree with you there. I have had this code numerous times. First was using a 50:50 valve, so only a small amount of air escaping. Second was a literal tiny leak around the map sensor, fixed it with bathroom sealant. Third was a small misalignment of the throttle body.
Have you had the TB off? Did you fit a new gasket when you refitted it?
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
I haven't taken the TB off but I did clean it with carb cleaner
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
but this is hard limp mode, it won't come out of it! I only get the following fault code:
17705, which I've always had when it was boost to 1.2-1.4 Bar
Pyro
Fair play then I had three Leaks In the IC pipework but never got limp :D lol guess each cars different ;) lol
DannyC87
Mar 4, 2008
3,459
you have fitted your n75 the correct way round haven't you??
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
this is what I have done for the removal:
