Small boost leak won't cause it mate I'd would imagine if there's a leak it'll be quite big get the logs done logging your boost and maf and go from there :)
mo can you run some maf logs on vagcom. new mafs are also known to be faulty before they even get fitted to a car.
Not sure I agree with you there. I have had this code numerous times. First was using a 50:50 valve, so only a small amount of air escaping. Second was a literal tiny leak around the map sensor, fixed it with bathroom sealant. Third was a small misalignment of the throttle body.
Have you had the TB off? Did you fit a new gasket when you refitted it?
I haven't taken the TB off but I did clean it with carb cleaner
but this is hard limp mode, it won't come out of it! I only get the following fault code:
17705, which I've always had when it was boost to 1.2-1.4 Bar
Fair play then I had three Leaks In the IC pipework but never got limp :D lol guess each cars different ;) lol
you have fitted your n75 the correct way round haven't you??
this is what I have done for the removal:
