Alright, everyone,
I'm starting the next retrofit project.
This time it's the Octavia Mk3 facelift again.
This time, we're converting to LED headlights. I'm intentionally not listing the part number because I have L0L as my PR code, meaning it's for right-hand traffic.
What's needed:
Left headlight with LED control unit
Right headlight with LED control unit
Multifunctional control unit (4B)
Axle level sensor rear axle
Wiring harness
I also need:
Front bumper with headlight washer system
Hose for the headlight washer system
Container for headlight washer fluid
How do I approach this issue:
- Removing the entire old bumper
- Removing the headlights
- Removing the old washer fluid container
- Installing the wiring harness from the headlights to the bulkhead and controlling the headlight washer system
- Then I roughly installed and secured the LED headlights.
The wiring harness consists of the left headlight, right headlight, rear axle level sensor, and the 4B control unit.
The wiring harnesses are routed in a slotted corrugated tube for protection.
That took 2 hours of work today.
The next steps are to route the high beam and pump wiring into the interior. This requires removing the battery and the housing.
What's needed:
Wiring harness
I also need:
