did the original xenon headlights work when simply plugged in did you need to change the looms/wiring etc ? i have been offered some original xenon headlights from a damaged car just want to know if its worth me buying them ???
check the guide i wrote search under my name.
its easy you just need to change the connector and activate the xenon via vag com, in the guide its all written
ok i dont fancy modifying the wriring to be honest how did you find it seremotors
can i use my original connector or do i have to buy new ones? also did you say i have to change something in the ecu, what forus is the installation guide in ?
ok thanks it seems a little tricky to me i might just leave them i dont want to alter connections etc would of prefered direct plug and play
thanks anyway
you mention this vag com system do i need to change the software or my ecu after the lights have been installed?
do you know anything about how vag works ?
vag com just tell the electrical unit the car now has xenon instead of halogen this can be done with the diagnostic tool from vag dealers if the are willing to do it, my dealer did it.
if you dont do it, they will turn on and after a couple of seconds they will turn off, as the car thinks it has halogen that consume 55w and they xenon only consume 35w so the car thinks the halogen are burnt and shut them off
ok sounds good to me i have a freind who recently reset my airbag light on my dash as i took the front seats out is that a vag system ?
i will do mate i have been offered some original xenon headlights for £350 so i might buy them how much are the connectors and could i buy them from a main dealer ?
