Reverse light
rocky2008
Buy Cheap Buy Twice!
Nov 16, 2008
1,029
North-east
hi all, just put a new reverse light in today as the old one had appeared to have gone, how ever it is not working, could this be a falty switch and is not recognising when the car is in reverse gear?
obou
Leon pd150
iv got the same problem and it seemes for me that it the bit the light connects into i take mine all out sort it out works fine then shut the boot and its out agian such a pain think i need a new rear light assemble but il try a few things out first :D
Mar 16, 2008
692
Wiltshire / Bristol
If you open the drivers door, look at the end of the dash. The plate right at the end comes of (youll need a flat head screwdriver to prise it on the left side). It can be a bit of a pain I find. Should be a 5A fuse, id think.
If you check all of the fuses and they are OK, you could try puting a volt meter across the contacts in the light cluster to make sure its not just a bad connection.
rocky2008
Nov 16, 2008
1,029
North-east
ah right mate thanks alot, is it cleary stated which fuses are for which in there, or will i need to try and find a picture of a fuse card?
Mar 16, 2008
692
Wiltshire / Bristol
From memory its not very clear atall. Just try pulling out all the orange fuses to see if theyre blown. if not you could try the others. There is a siagram of which fuse does what, but I cant find it - sorry!
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Do not just go pulling random fuses out.
Some of those fuses may cause air bag lights to come up if you dont disconect the battery first.
The fuses are designed so that you can see if there is a blown one, just look at the metal blade part of the fuses and see if any look blown. (pictures in the owners hand book)
Personally I don't think it will be a fuse, I doubt that there is a fuse that's only job is to protect one reverse lamp. If there was a fuse gone I would expect other lamps to be dead too.
see these 2 pics below for what to look for, you do not really need to remove fuses to tell it they are blown, you can see from the end that shows.
http://www.societyofrobots.com/images/electronics_fuse_not_blown.jpg
http://www.procarcare.com/images/shar/encyclopedia/8852dg21.gif
692
Wiltshire / Bristol
In my experience it is difficult to impossible to tell if a fuse is blown without looking from the side. I wouldnt have thought you would have had problems with airbag lights, but am always willing to be proven wrong.
Ive just had a look in the handbook and there is a single 15A fuse which soley runs the reverse light. It is fuse 19 which is one of the small fuses at the top. It is 3 across from the right, and 4 down. (have a look at the little fuse card to check if your not sure)
chrisinit
I have the same problem and they said it wasn't a warranty repair, it was just some wires that had gone, still to find them yet though! Suppose i should take the battery out and have a look at the switch. Does anyone have a picture of the top of the gear box and the switch i should be looking for?
B3NNO
I've too had a similar problem spent a couple of hours checking bulbs and fuses, finally i thought it may have been the gearbox switch, but when i took it in to the seat garage, it turned out to be a wire running from the gearbox to the front of the car (sorry cant get any more technically then that as the technicians didn't say much else).
Oct 17, 2006
2,141
Mid Wales
Are you sure it's a 15A fuse solely for the reverse light?
That's a 55W lamp IIRC, so at 12V that's only capable of pulling 4.6A - it makes no sense for it to be fused up to 15A surely?
