Right I bought a Cree bulb which flickers due to having a DSG box. So I've also got a resistor too. Tried resistor and the flickering has stopped. Excellent. Now big question, how can I wire it in permanently? It's a 3 door Boc.
I'm ok with electrics but car electrics baffle me...lol.
Thanks in advance.
Thanks in advance.
I assume the resistor goes across the pos and neg terminals of the led to stop the flicker ?
If that is the case - you could solder the resistor across the relevant tracks of the rear light cluster to give the same effect.
Thanks for all the advice on this forum.
I have now plumped for replacing the reversing light with this item 1pc CREE 1156 BA15S P21W Xenon LED CANBUS REVERSE LIGHT BULB WHITE HIGH POWER 261169683340.
There are several like this ranging from£22.50 to £9.90 to £8.95. I went for the latter as they offer a refund if it doesn't work out. They are one of several companies that sell in the bottom range on Fleabay. They are all the same!
The bulb's circuit board has CREE on it but whether it is a CREE or not it is rated at 380 Lumens
I can only say that the difference is like night and day. Massive improvement so that I can recommend this minor upgrade without reservation.
Only regret is that the glowworm was evicted.
PS Don't forget to check the operation with the boot lid shut.
I'd post some pics but photos of lights are notoriously unreliable and misleading but if you insist I could put up some before and afters
See here for main thread http://www.seatcupra.net/forums/showthread.php?p=4338161&posted=1#post4338161
3dr FR reverse bulb
Just checked my 3dr 13reg FR and yup teh bulbs a W16W 12V. looks like a oversized 501. Ordered mine from autoperformanceonline ebay shop.
I have had these brighter bulbs for ages now and I love them, but it's MOT day tomorrow - will they cause a fail? Should I put the original ones back in for the test? Thanks in advance guys!
