Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Running HB2T5, after 5k the N75 duty starts to drop and the boost drops away. Should a K04 not be reequesting more?
Code:
Engine RPM	Air Mass Flow	Throttle Opening	Ign. Timing	Engine Speed	Load	req psi	del psi	Engine Speed	Intake Temp	N75 Duty Cycle	Press @ Intercool
 /min	 g/s	%	°	 /min	%			 /min	°C	%	 mbar
1480	29.89	59.6	20.3	1320	78.2	8.8	1.0	1320	37	95.3	1100
1360	21.97	66.3	13.5	1440	84.2	10.3	2.2	1560	34	95.3	1170
1720	31.33	83.5	15.8	1760	95.5	12.3	3.8	1800	32	95.3	1290
1960	38.47	96.5	15	2040	105.3	14.3	5.6	2120	31	95.3	1430
2240	52.17	100	15.8	2320	127.8	14.7	8.5	2440	30	84.7	1700
2560	75.19	100	13.5	2800	162.4	18.7	14.0	2880	30	80	2210
3080	112.56	100	6.8	3160	190.2	20.4	20.1	3280	30	84.7	2400
3320	122.53	100	7.5	3320	191.7	20.4	20.4	3360	30	84.3	2390
3440	128.08	100	9.8	3560	191.7	20.6	20.3	3600	30	85.1	2380
3760	138.67	100	12	3840	191.7	20.3	20.3	3920	32	84.7	2380
4040	149.94	100	12	4120	191.7	20.1	20.3	4200	34	83.9	2370
4320	160.89	100	9	4400	191.7	20.1	20.1	4520	36	83.9	2380
4600	171.56	100	9.8	4680	191.7	20.1	19.8	4800	39	83.9	2360
4880	182.25	100	8.3	5000	191.7	19.7	19.7	5080	43	86.7	2320
5200	192.75	100	10.5	5280	191.7	19.3	19.7	5360	47	85.5	2340
5440	193.83	100	8.3	5520	186.5	19.3	19.1	5600	51	87.5	2300
5680	197.92	100	6.8	5760	175.2	16.6	17.6	5840	54	81.2	2170
5920	195.33	100	12	6000	172.9	13.1	17.3	6080	57	66.7	2060
6120	175.78	100	14.3	6200	143.6	10.9	12.6	6280	60	54.1	1810
6320	161.36	92.2	13.5	6400	130.8	9.4	11.2	6480	61	15.7	1770
Is it as simple as turning the boost up with the SPS3?
At 6k the N75 duty is only 54%, so its venting half the boost!
had you started to ease back at 6k?
The 5680 figures look respectable, good airflow etc
inlet temps had risen too - so it's possible it started to pull back slightly
These were taking whilst on a RR, the operator was driving. Dont think he lifted off til after 6300rpm.
Made 230bhp and 270lb.ft.
Will changing to HB5 bring in the boost higher up?
Unless the CF's are off the scale, but i'd expect to see that down low tho.
As i said on the other thread HB2 T5 are really soft settings.
Done some logging tonight and the N75 duty is now at 80% over 6k with HB5, instead of <60% when on HB2. Holding 16.5psi @ 6.5k.
CF's are max of 3, and the timing is on 5.
Logged speed too, 0-60: 6, 0-100: 13.4 :)
Post them up. We like logs on SCN.
(This is the CF and boost log, not the speed run.)
Code:
	Group A:	'115				Group B:	'118				Group C:	'020
		Engine Speed	Load	Req	Act		Engine Speed	Temp	N75 Duty	Press @ Intercool		Cyl #1	Cyl #2	Cyl #3	Cyl #4
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar	STAMP	 CF	 CF	 CF	 CF
	445.6	1800	52.6	0.44	0.74	446.1	1600	24	95.3	1090	446.5	0	0	0	0
	446.9	1680	94	11.03	2.79	447.3	1720	23	95.3	1240	447.7	0	0	0	0
	448.1	1840	103.8	12.35	4.70	448.5	1920	21	95.3	1370	448.9	0	0	0	0
	449.3	2080	117.3	13.38	6.76	449.7	2160	21	95.3	1530	450.1	0	0	0	0
	450.5	2360	143.6	13.97	10.29	450.9	2440	21	72.9	1810	451.3	0	0	0	0
	451.7	2720	164.7	17.05	13.97	452.1	2840	21	77.6	2040	452.59	0	0	0	0
	452.99	3440	191.7	20.29	18.96	453.39	3680	21	84.3	2350	453.79	0	0	0	0
	454.21	3800	191.7	20.29	20.43	454.69	3800	23	84.3	2380	455.1	0	0	0	0
	455.5	4080	191.7	20.14	20.14	456	4240	24	83.1	2340	456.4	3	0	3	3
	456.8	4520	191.7	19.85	19.85	457.2	4640	27	83.1	2350	457.6	2.3	0	3	3
	458	4880	191.7	19.11	19.40	458.4	5000	29	83.1	2300	458.8	2.3	0	2.3	2.3
	459.2	5240	191.7	18.82	18.82	459.6	5360	31	83.5	2250	460	1.5	0	2.3	2.3
	460.4	5560	185.7	18.08	17.79	460.8	5680	33	83.9	2210	461.2	1.5	3	1.5	4.5
	461.6	5880	178.9	17.05	17.35	462	5920	36	88.2	2160	462.4	1.5	3	1.5	4.5
	462.8	6120	175.9	16.61	17.20	463.2	6200	38	87.5	2180	463.6	3.8	2.3	0.8	4.5
	464	6320	169.9	15.88	17.05	464.49	6440	40	86.3	2160	465	3.8	2.3	0.8	3.8
	465.4	6560	161.7	14.41	16.46	465.8	6600	43	85.1	2110	466.2	0	0	0	0
(and now the speed run)
Code:
	Group A:	'005
	TIME	Engine RPM	Engine Load	Vehicle Speed	throttle
	TIME
MARKER	STAMP	 /min	%	 km/h
0	202.28	2760	15.8	0	Part Throttle
0.9	203.18	3040	141.4	3	Part Throttle
1.81	204.09	4240	191.7	29	Part Throttle
2.61	204.89	6560	154.9	49	Idle
3.49	205.77	4960	191.7	61	Part Throttle
4.31	206.59	6000	175.2	77	Part Throttle
5.11	207.39	6880	88.7	89	Idle
6	208.28	5040	191.7	99	Part Throttle
6.9	209.18	5640	183.5	109	Part Throttle
7.7	209.98	6080	172.9	119	Part Throttle
8.5	210.78	6480	162.4	127	Part Throttle
9.3	211.58	5680	120.3	132	Part Throttle
10.21	212.49	5360	188.7	139	Part Throttle
11.01	213.29	5600	183.5	145	Part Throttle
11.81	214.09	5800	176.7	151	Part Throttle
12.61	214.89	6000	174.4	156	Part Throttle
13.41	215.69	6200	170.7	161	Part Throttle
14.19	216.47	6400	165.4	166	Part Throttle
14.99	217.27	6600	14.3	169	Idle
15.81	218.09	5200	189.5	171	Part Throttle
16.61	218.89	5320	191.7	175	Part Throttle
After searching for some LCR logs, holding 14psi to 7k seems to be the benchmark. I never took it that far tonight, but don't think it will be far off that.
