RR today graph inside help required please
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
115 is in post 15 too or did you want 115 and another block measured together?
And when i loan a MAF what blocks do you want? 002?
Also here's my graph from Oct 2008 at the same rollers
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Please please please will folks stop logging three blocks at a time!
It's easier to for us to help if we use the usual format.
003 020
115 031
118 032
On Lee's logs 115 the last column (actual) is missing................
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
This better?
Code:
115
Engine Speed	Engine Load	Spec. Boost	Actual Boost
700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
 /min	%	 mbar	 mbar
1920	81.2	1050	1280
2080	105.3	1370	1390
2240	96.2	1410	1340
2360	113.5	1470	1460
2560	125.6	1670	1630
2760	135.3	1750	1740
3000	137.6	1750	1740
3280	137.6	1710	1700
3560	134.6	1680	1650
3920	134.6	1720	1690
4240	136.8	1720	1710
4560	137.6	1720	1700
4880	138.3	1720	1710
5200	139.8	1740	1720
5480	141.4	1760	1740
5720	139.8	1720	1730
5920	133.8	1690	1700
6160	134.6	1680	1660
4840	12	1000	1090
3240	12.8	1000	1040
1840	13.5	1000	1030
960	14.3	1000	1020
720	21.8	1000	1010
760	17.3	1000	1010
720	18.8	1000	1010
720	18.8	1000	1010
760	17.3	1000	1010
760	16.5	1000	1010
720	15.8	1000	1010
720	16.5	1000	1010
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
looking at those, requested is meeting actual, but the ecu isn't requesting anything hard. Looks like limp mode................. Duty cycle would seem to support that.....
Sorry - gota go - back later. :)
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Ok thanks Dave.
No fault codes are stored, could it be a simple case of the re-map not requesting a harder boost?
Does anyone have a standard graph of a AUQ 180 to compare to mine?
Aug 24, 2007
800
Not standard Lee but may be of some use. My car with a massive breathing problem stopping the map from working (split breathers).
S3 Nattie
120
I logged a 1.8T stage 1 the other day and it was getting 156 g/s. Your cars making the requested boost but like said isnt requesting much.
I dont think you have a problem with your car but the map is not the best for bringing out the performance of the car
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
He took it for a drive " to check it was doing things it should be" yes it's different to drive than it was.
The guy who sent them the map said some of the check sums were not what they should have been, they think a possibility was that it might have been mapped before then a different mapped added, they weren't sure though.
All beyond me hence all my questions lol
They offer a refund/lifetime guarantee.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
just go back to them lee, get them to reflash the map, tell them its not right and you want it on the rollers before and after to check.
still maf is too low for stage1, but if thats whats being requested.
they think ures was mapped before... shouldnt make a difference tbh, the new map should flash over.
james walker
May 24, 2007
5,121
retford notts
oh ok, well it will still be ok for generic mapping.
ask them to reflash it and log again whilst your there to confirm its running fine, could be a bug in the software, seen it happen before.
timing pull needs looking at lee, upto 8degrees there, 5 is generally ok, but as your pretty much standard then i wouldnt expect to see much in that block.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Having looked at 114, I actually think there's nothing wrong. Everything is working as it should do. N75 is controlling boost as requested. What the map is, I wouldn't like to say.... Standard - or a mapper's version of standard?
