gingerben
72
Hiya all just a quicky,
Got a jetex cone filter on the way and just realised i need a filter for the SAI system, please could a couple of you post a few links to where i could get a cheep one, at work all day so will just check back occasionally.
All the best
Ben
cheers jamjay,
any one elce got any ideas ill pop down halfords on thursday got a day off so see what i can sort out then, air filter should be here then aswell so hopefully get a few pics up after love the look of a blue cone lol
Whereabouts do you put this filter? I'm gonna be replacing my airbox for a cone filter in the near future, and would like to get an idea before i fit it. A pic would be good ;)
I Should be doin this all 2morro m8, so will try and gets some pics as im doin it, the new filter go's onto the pipe that conected to the big air box. It might have to be a sock as mentioned above tho till i can get one, but ill see what i can get 2morro lol
I got a breather filter which came with my bmc induction kit, looks like a mini cone filter. problem fitting it though as everytime I did the jubilee up it folded the plastic pipe up and squeezed the filter end out of the pipe, any ideas how to sort it out? Tried cable tie-ing it to but did the same thing
hiya all
Got mine on today, sounds sweet, ill put some pics up over weekend as gonna do the mod that Jon has done with the bush into the top of the filter, i am still not convinced on holding the sai filter inplace, there must be quite a few peeps on here with cone filters with ideas, or maby alot of them have just removed the sai system??,
Just for the recorded i didnt get the same filter as every 1 here seems to be getting i got one with a 90mm i/d, 140mm top 100mm bottom with 203 lenght and its spot on about 1cm gap if that, to side of car with oem mount perfect for the bushing mod, i had to get a 70 to 90mm silicon converter as i have a facelift cupra but over all very happy, as didnt want a small compact filter and the only way to get this is to get a bigger inlet diamater, as i said will get some pics up weekend so you can see what i looks like.
