dubstar_71
My 2.0 tdi (BKD engine) altea is running fine, average fuel consumption, but just isn't pulling as well as a friends standard 2.0 tdi (BKD engine) golf.
Which are the appropriate measuring blocks to check for indicators of the cause(s) of poor performance?
Hi there, I can't remember the blocks off the top of my head but i'd put money on it that your MAF is on the blink. If you can lay your hands on a torx security bit to undo the screws, I would swap over the MAF for the one in your mates golf and give it a try. Last time I priced a MAF it was a bit expensive (£90 for a golf mk4, exchange at dealers) but it did sort out the hesitation and lack of power.
,Group A:,'010,,,,Group B:,'011,,,,Group C:,'012
,,Mass Air Flow,Atmospheric,Boost Pressure,Accel. Pedal Pos.,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure,,Glow Status,Pre-Glow Period,Supply Voltage,Coolant
,TIME,(actual),Pressure,(actual),Sensor 1 (G79),TIME,(G28),(specified),(actual),Control Duty Cycle,TIME,,,(Terminal 30),Temperature (G62)
Marker,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %,STAMP,, s, V,°C
,0.33,505.0,1009.8,1519.8,32.5,0.00,1701,1479.0,1489.2,68.9,0.17,11111111,0.00,14.36,85.5
,0.89,715.0,1009.8,1550.4,100.0,0.55,1722,1519.8,1540.2,68.1,0.72,11111111,0.00,14.36,85.5
,1.44,1140.0,1009.8,2091.0,100.0,1.11,1785,2397.0,1693.2,69.7,1.28,11111111,0.00,14.29,85.5
,1.97,1275.0,1009.8,2601.0,100.0,1.65,1911,2437.8,2356.2,48.2,1.81,11111111,0.00,14.36,85.5
,2.50,970.0,1009.8,2601.0,100.0,2.18,2016,2539.8,2601.0,27.1,2.34,11111111,0.00,14.36,85.5
,3.06,1265.0,1009.8,2601.0,100.0,2.72,2163,2539.8,2601.0,43.0,2.89,11111111,0.00,14.29,85.5
,3.58,1180.0,1009.8,2601.0,100.0,3.26,2310,2539.8,2601.0,29.1,3.42,11111111,0.00,14.29,85.5
,4.14,1180.0,1009.8,2601.0,100.0,3.80,2436,2539.8,2601.0,34.7,3.97,11111111,0.00,14.29,85.5
,4.67,1190.0,1009.8,2601.0,100.0,4.34,2562,2539.8,2601.0,31.9,4.50,11111111,0.00,14.29,85.5
,5.19,1170.0,1009.8,2601.0,100.0,4.87,2688,2519.4,2601.0,28.3,5.03,11111111,0.00,14.29,86.4
,5.74,1150.0,1009.8,2590.8,100.0,5.41,2835,2499.0,2601.0,26.3,5.58,11111111,0.00,14.36,86.4
,6.27,1140.0,1009.8,2560.2,100.0,5.95,2940,2478.6,2580.6,25.5,6.11,11111111,0.00,14.36,86.4
,6.80,1130.0,1009.8,2550.0,100.0,6.48,3045,2468.4,2560.2,24.3,6.64,11111111,0.00,14.29,86.4
,7.36,1115.0,1009.8,2539.8,100.0,7.02,3171,2458.2,2550.0,22.3,7.19,11111111,0.00,14.36,86.4
,7.92,1110.0,1009.8,2519.4,100.0,7.58,3276,2437.8,2529.6,20.7,7.75,11111111,0.00,14.29,86.4
,8.47,1085.0,1009.8,2488.8,100.0,8.13,3402,2417.4,2509.2,18.7,8.30,11111111,0.00,14.36,86.4
,9.00,1070.0,1009.8,2448.0,100.0,8.68,3507,2397.0,2468.4,17.5,8.84,11111111,0.00,14.36,86.4
,9.55,1050.0,1009.8,2407.2,100.0,9.22,3612,2376.6,2437.8,15.5,9.38,11111111,0.00,14.36,86.4
,10.08,1035.0,1009.8,2376.6,100.0,9.76,3717,2366.4,2386.8,13.9,9.92,11111111,0.00,14.36,86.4
,10.64,1025.0,1009.8,2335.8,100.0,10.30,3822,2335.8,2356.2,12.4,10.47,11111111,0.00,14.36,87.3
,11.19,1010.0,1009.8,2315.4,100.0,10.86,3906,2305.2,2335.8,10.0,11.03,11111111,0.00,14.36,87.3
,11.75,985.0,1009.8,2284.8,17.6,11.41,3990,2274.6,2305.2,8.4,11.58,11111111,0.00,14.36,87.3
,12.28,755.0,1009.8,1774.8,0.0,11.95,3906,1081.2,2142.0,43.8,12.11,11111111,0.00,14.36,87.3
,12.80,1175.0,1009.8,1999.2,100.0,12.48,3066,1672.8,1672.8,71.7,12.64,11111111,0.00,14.36,87.3
,13.36,1175.0,1009.8,2601.0,100.0,13.02,3213,2458.2,2560.2,24.7,13.19,11111111,0.00,14.36,87.3
,13.92,1115.0,1009.8,2560.2,100.0,13.58,3255,2448.0,2601.0,26.7,13.75,11111111,0.00,14.36,87.3
,14.48,1110.0,1009.8,2550.0,100.0,14.12,3318,2437.8,2550.0,26.7,14.28,11111111,0.00,14.36,87.3
,15.03,1120.0,1009.8,2550.0,100.0,14.69,3381,2427.6,2550.0,24.7,14.86,11111111,0.00,14.36,88.2
,15.55,1075.0,1009.8,2529.6,0.0,15.23,3423,2407.2,2550.0,22.3,15.39,11111111,0.00,14.36,88.2
,16.08,720.0,1009.8,1785.0,0.0,15.76,3360,1050.6,2111.4,47.8,15.92,11111111,0.00,14.36,88.2
,16.64,660.0,1009.8,1560.6,0.0,16.30,3360,1050.6,1672.8,48.2,16.47,11111111,0.00,14.36,88.2
,17.16,630.0,1009.8,1468.8,0.0,16.84,3318,1050.6,1519.8,48.2,17.00,11111111,0.00,14.36,88.2
,17.69,620.0,1009.8,1428.0,0.0,17.37,3276,1050.6,1448.4,48.6,17.53,11111111,0.00,14.36,88.2
,18.25,620.0,1009.8,1397.4,0.0,17.91,3213,1050.6,1417.8,49.4,18.08,11111111,0.00,14.36,88.2
,18.80,605.0,1009.8,1387.2,0.0,18.47,3192,1050.6,1397.4,49.8,18.64,11111111,0.00,14.36,88.2
,19.36,595.0,1009.8,1366.8,0.0,19.02,3150,1050.6,1377.0,49.8,19.19,11111111,0.00,14.36,89.1
,19.92,590.0,1009.8,1346.4,0.0,19.58,3087,1050.6,1356.6,50.6,19.75,11111111,0.00,14.36,89.1
,20.47,580.0,1009.8,1326.0,0.0,20.13,3066,1050.6,1336.2,50.6,20.30,11111111,0.00,14.36,89.1
,21.00,575.0,1009.8,1315.8,0.0,20.67,3045,1050.6,1326.0,51.0,20.83,11111111,0.00,14.36,89.1
,21.55,580.0,1009.8,1305.6,0.0,21.22,2982,1050.6,1305.6,51.8,21.39,11111111,0.00,14.36,89.1
,22.11,570.0,1009.8,1295.4,0.0,21.77,2940,1050.6,1305.6,52.6,21.94,11111111,0.00,14.36,89.1
,60.11,840.0,1009.8,1825.8,44.3,60.33,1491,1734.0,1876.8,61.4,60.48,11111111,0.00,14.36,89.1
,60.66,885.0,1009.8,1938.0,46.3,60.88,1533,2131.8,1978.8,66.1,61.05,11111111,0.00,14.36,89.1
,61.22,1125.0,1009.8,2244.0,100.0,61.42,1596,2223.6,2366.4,49.8,61.58,11111111,0.00,14.36,89.1
,61.74,1205.0,1009.8,2519.4,100.0,61.96,1680,2295.0,2601.0,34.7,62.13,11111111,0.00,14.36,89.1
,62.30,1275.0,1009.8,2601.0,100.0,62.52,1764,2397.0,2601.0,45.4,62.69,11111111,0.00,14.36,89.1
,62.86,1025.0,1009.8,2386.8,100.0,63.07,1848,2417.4,2386.8,48.2,63.24,11111111,0.00,14.36,89.1
,63.41,1120.0,1009.8,2417.4,100.0,63.63,1932,2458.2,2458.2,46.2,63.80,11111111,0.00,14.36,89.1
,63.96,1170.0,1009.8,2539.8,100.0,64.17,1995,2539.8,2590.8,41.4,64.33,11111111,0.00,14.36,90.0
,64.50,1230.0,1009.8,2601.0,100.0,64.70,2079,2539.8,2601.0,32.7,64.86,11111111,0.00,14.36,90.0
,65.02,1185.0,1009.8,2601.0,100.0,65.24,2163,2539.8,2601.0,35.5,65.41,11111111,0.00,14.36,90.0
,65.58,1160.0,1009.8,2601.0,100.0,65.80,2226,2539.8,2601.0,34.7,65.96,11111111,0.00,14.36,90.0
,66.13,1165.0,1009.8,2601.0,100.0,66.35,2331,2539.8,2601.0,32.7,66.52,11111111,0.00,14.36,90.0
,66.69,1170.0,1009.8,2601.0,100.0,66.91,2394,2539.8,2601.0,31.5,67.08,11111111,0.00,14.36,90.0
,67.25,1165.0,1009.8,2601.0,100.0,67.44,2478,2539.8,2601.0,30.3,67.61,11111111,0.00,14.36,90.0
,67.77,1150.0,1009.8,2601.0,100.0,67.99,2562,2539.8,2601.0,29.1,68.16,11111111,0.00,14.36,90.0
,68.33,1135.0,1009.8,2601.0,100.0,68.54,2625,2529.6,2580.6,28.3,68.71,11111111,0.00,14.36,90.0
,68.88,1130.0,1009.8,2560.2,100.0,69.10,2709,2519.4,2550.0,27.1,69.27,11111111,0.00,14.36,90.0
,69.44,1135.0,1009.8,2539.8,100.0,69.66,2772,2509.2,2539.8,26.3,69.82,11111111,0.00,14.36,90.0
,69.99,1120.0,1009.8,2539.8,100.0,70.20,2835,2499.0,2529.6,25.1,70.36,11111111,0.00,14.36,90.0
,70.52,1125.0,1009.8,2529.6,100.0,70.74,2898,2488.8,2529.6,23.1,70.90,11111111,0.00,14.36,90.0
,71.08,1125.0,1009.8,2519.4,100.0,71.30,2961,2478.6,2519.4,22.3,71.47,11111111,0.00,14.36,90.0
,71.64,1105.0,1009.8,2509.2,100.0,71.84,3045,2468.4,2509.2,21.1,72.02,11111111,0.00,14.36,90.0
,72.18,1105.0,1009.8,2499.0,100.0,72.38,3087,2468.4,2499.0,20.3,72.54,11111111,0.00,14.36,90.9
,72.71,1105.0,1009.8,2488.8,100.0,72.92,3150,2458.2,2478.6,19.9,73.08,11111111,0.00,14.36,90.9
,73.25,1090.0,1009.8,2478.6,100.0,73.45,3213,2458.2,2478.6,18.7,73.63,11111111,0.00,14.36,90.9
,73.80,1095.0,1009.8,2478.6,100.0,74.00,3255,2448.0,2478.6,17.9,74.16,11111111,0.00,14.36,90.9
,74.33,1085.0,1009.8,2468.4,100.0,74.52,3318,2437.8,2468.4,16.7,74.70,11111111,0.00,14.36,90.9
,74.86,1105.0,1009.8,2468.4,100.0,75.06,3381,2427.6,2458.2,15.9,75.22,11111111,0.00,14.36,90.9
,75.38,1070.0,1009.8,2448.0,100.0,75.60,3423,2417.4,2448.0,15.1,75.77,11111111,0.00,14.36,90.9
Seems ok yes?
