Would it not be possible to run it hydraulically
if you can find and install a TDI bulkhead and pedal box assy then ye - TDI was the only mk2 hydraulic, not an easy bolt in sorry - looked at it a few times
checked my spare box but came without it sorry chris
it would be an epic pain to run a hydraulic clutch, cable is what i've got so i'll stay :)
any ideas where i might be able to get the part number flapper?
do these look like the parts?
02B 141 708A bearing bracket
02A 141 728 boot
02A 141 730 toothed lock washer
02A 141 740A push rod
357199356 - Cable Clutch Cable/Engine Mount Bracket
16v cable assy as it's longer
need to see the box but as you are after the conversion parts i would guess you'll need the mounting bracket too (9) added to the one thats there
8 9 18 17 16 15 14 10 11 12 13
pretty much all of it :)
