Hello guys,
I'm new to this forum and I have a issue with my Seat Ibiza 6L 2006, 1.4 16V BKY, I've already did some reading about this common problem however I couldn't get it fixed.
I was messing with my dash cluster and tried replacing the speaker inside, however when I reconnected the dash it was flashing immobiliser light and half of indicator lamps didn't light up (like check engine, brakes, etc, there was no communication between ECU and dash cluster
I took my car to Seat service and ordered a new cluster, they had difficulties to adapt it, so they re-ordered it under the part warranty (we thought that cluster which arrived first time might be damaged in some way). However that didn't help, and they said that they'll have to replace ECU, dash cluster and keys aswell which is extremly expensive. So I decided to take my car from them.
I did some reading on this and other forums aswell on how to swap cluster but I'm still not quite sure how to do it. I have a brand new cluster which I bought from Seat service and I did not mess with anything on car so I'm quite confident that I didn't disconnect any ground line or something like that. ECU is OK, keys are OK aswell.
My basic understanding is that since I can't access old instrument cluster, I'll have to access ECU somehow and get that SDK file to obtain PIN which I will use to adapt the new cluster. How to retrieve PIN from ECU?
Thanks for your help!
