SEAT PORTABLE SYSTEM [GARMIN] Skins & Hacking
at0ny
155
32
Holland
Hello,
Thank you for this brilliant program / hack.
I have only two questions,
Can I display the bar for my Ibiza 1.2l 77kw (iTech) set so that it shows me the tazäcjlichen pressure, because he shows me in the state at 0.8 bar and then it would have to be 0 or?
And the G display does not work, I have no sensors or did I do something wrong?
Thanks in advance
Hello,
Thanks in advance
I have the same problem. The boost gauge stays on 1 bar pressure en with trottle it goes to 2 bar. Maybe a wrong scale? I have a 2014 Fr 1.2 maped 133hp
Popa Octavian
Pher,can you upload again the kbi tools version 10? I want to change the size of pnx file in mn8 skin,but with v11 something is going wrong and is not working! All images are shown transparent.
at0ny
155
32
Holland
Any updates for version 7.16.9?
And have someone working radio logo's on the Garmin system? Downloaded them with Garmin fresh but they dont show. Is there a way to get then work?
Verstuurd vanaf mijn SM-G965F met Tapatalk
vgf
hi guys,anyone can confirm that this version of modified SPS can read the PIDs for oil temp & pressure? for a 1.4 tsi cupra (2009). thank you. cheers
Jan 29, 2020
Hi guys,
as promised i will share a process that will make possible extract the bitmaps contained in some of the .nfs files present in the SEAT PORTABLE SYSTEM.
This method will work on the GARMIN version. For the NAVIGON users i can't say if it will work, just give it a try and say your veredict.
The files that contain car related bitmaps are present in the VwUserShell folder. Remember always to save backup copies from this files.
For now, this method will require 3 diferent software tools.
The process is the folowing:
1) Use the NFSExtractor v0.8 from KlingMeiDing for extract all the content. This content is almost .kbi files that contain the usefull bitmaps.
2) To extract the content from .kbi files use the KBIExtractor tool. This content could be binary data and the wanted bitmaps. The bitmaps are present in the Bitmaps_480x272.kbi file.
3) The bitmaps that are present in the .kbi file are in PNX format. To convert that files to a more convinient image file (PNG), use the PNX-Converter tool.
With this process you will gain access to all the bitmaps present of the .nfs files. For now, this method will not allow to generate the .nfs files with custom bitmaps. In the next days i will try to build a tool that could make the opposite process.
All this tools can be downloaded from:
NFSExtractor v0.8 - http://www.china-rns.com/downloads/tools-27/nfsextractor-v0-8-532/
KBIExtractor - http://www.4shared.com/rar/dIJxDLhfce/KBI_Extractor_v11.html
KBICompressor - http://www.4shared.com/rar/aJA7pJGHce/KBI_Compressor_v11.html
PNX-Converter - http://www.4shared.com/rar/n9f2-Hztce/PNX-Converter.html
Just a message for FR owners. The new VwUserShell.exe that will enable the performance display in FR models can be downloaded from:
http://www.4shared.com/rar/LBMLXofGba/VwUserShell_714.html
Just replace the file present in the VwUserShell folder. Always remember to save a copy of the original file.
Hi tried to use this link but it’s now dead. I Want to install the Cupra options to my FR Garmin (mainly for oil temp). Can anyone help? A link was recently put on FB that didn’t work. Cheers
Tiago_cupra
10
Do you know what I have to do to get the performance gauge? I have replaced the file and it isn't there do i have to download something else?
Yes you can do it.
You might need some more files.
I read it somewhere here on the forum. I will try to find it
