Pogostix
Hoping someone can point me in the right direction.
Basically went through a large puddle the other week in all the heavy rain and my nearside HID bulb went out, then when i get home the dancing lights stopped. Bumper came off and I found out it was not the bulb but a Xenon HID Headlamp Ballast Control Unit, so found a replacement OEM part on Ebay. This fixed the headlight bulb not working but not the dancing lights left and right. Further investigation suggested it may be the Headlight Module Blast 7L6941329A. So I have replaced that with an identical secondhand genuine part, however although the lights go up and down to level, there is still no left or right movement for cornering. Help & advice required please as although I have the Ross-Tech software and cable i will need a little help to resolve this issue. Many thanks in advance.
Thursday,22,November,2018,11:53:39:46565
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 A HW: 5M0 907 357 A
Component and/or Version: AFS-Steuergeraet X014
Software Coding: 2556165
Work Shop Code: WSC 01223 476 88101
Additional Info: 7L6941329A AFS-Lst.-Modul l 0002 7L6941329A AFS-Lst.-Modul r 0002
VCID: 326A92E1AD9A84D4E1-8066
3 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
