Normally it's up to 500 miles of easy driving, but generally do about 100 round towns using the clutch then see... can't say I've ever ragged a brand new clutch so cant say if slip in the early days is normal.
It's like brake discs and pads need to bed the friction plated to the metal.
I know its a totally different vehicle. But we had the work van done and it was still slipping, turned out to be a dodgy new clutch.
How bad is it slipping?
some bedding in is normal... but I dont think slippage is a good sign from new.
why is it ticking as you drive?
I fear the worst Pete.
MrsB's did'nt slip from new (only a nasty sachs power clutch in hers) - starting to slip a bit now 3 years on. mine does'nt has'nt ever slipped on SPEC, but these are obviously uprated.
G60 clutch torque spec (which I think is what should be in yours) should'nt be worried with 20VT revo torque.
what make went in?
fingers crossed for you.
they supplied & fitted the clutch Pete
I would be asking questions. Summats not working right there.
any news pete
