eyco
192
israel
basicly with the same T3s60 setup, just added HID's and replace my Greddy RS bov with a type R bov...
my girl;)
Greddy type RS
Greddy type R
love the wheels!!!:clap:
dont suppose you know if they are brembo friendly?
also, is that a different version of a cupra or something? everything is similar bar the front bumper.
lol thanks for the feedbacks;)
the hid's are 10k, thats my oem grill i choped the fins and put a net, bodyshop did the finish.
i guess the brembos will fit in, mybe you will need a 5mm spacer.
same car as the cupra just without the lather seats and badges, and a diffrent bumper.
love the wheels dude, LM's are one of my favourite wheels!
Wheres your MAF? Why are you running a power boost valve, im guessing your running some kind of standalone management to have no maf and a BOV...
i'm running the oem ecu chip by FRC a local tuner here in israel allso works with CC.
boost controled via Greddy profac A boost controoler, when it off i get WG 0.8bar, in low boost i set it to 1.3bar and hi boost set to 1.6bar.
i didnt want to use the MAF, car drives much much better without it! allso i cenceled the N75, N249 and secondery air pump, the car responds much more sherp.
i did vag-com log, fuel trim are ok, CF are A ok! EGT is perfect and i can use a BOV ;) so i'm happy :)
how have you removed the MAF but still kept the orginal ECU to run the engine, surely it defaults to a standard map if no MAF input is found?
more info please!
