Squeeky front LCR 02
davespeedie
Hi Folks,
My cupra has a horrible creaking sound from the front suspention. many garages have said different things that it could be, dry joints and bushes etc.... has anyone had this problem before? i took the strut brace off but it was even worse so it went straight back on, doesnt seem to do it when its wet, when im am turning and the camber of the road changes pitch it sounds like a squeeky barn door .
other than that the car is the nuts :)
Dave
brad1
top mounts as ben says, i sometimes get this, a slight creak at times, or worn shock? Defo replace the top mounts first and go from there i would say
Deleted member 19366
It sounds like your anti-roll bar mounts or the anti-roll it's self thats making this noise. Had same thing with mine the sleeve had split and caused the anti-roll to crack.
davespeedie
thank you very much guys i will investigate it has been driving me nuts but there is to much to adjust without having any idea of where to start looking
The anti-roll bar can be check with wheels on full lock while car is on the floor. Where abouts you from as it may be worth asking a seat vw specialist to have a look
