janowski1980
Platinum Grey
Dec 18, 2006
113
Hampshire
i hear lots of talk about a short shifter, what are these, how much and what do they do, appreciate any comback. Cheers also how are they fitted
fit on top of the gearbox (99% of cases)
range from 80-200 quid
reduce the distance the gear lever moves between 1st-2nd, 3rd-4th, 5th-6th
can also get parts which reduces the amount you move across the box
i would fit it yourself. i'm thechnically inept and i managed mine with the right tools. get a bearing puller prior to fitting incase the original part won't come off. if it comes off without the bearing puller then just take it back for a refund. I used the guide from the EIP website.
short shift is a superb mod IMO. good value too if you go for the forge or PSI tuning one.
