Vin-R
342
Midlands
Hi guys need a bit of advice please..
Was driving around tonight, outside temp was 4.5* Went on a bit of a blast and it was raining too.. .and really cold. Pulled up at tesco for a spot of shopping and i noticed steam coming from the bonnet???
Is this normal ??? is water from the road ??
Any one else noticed steam like this ???
"In the atmosphere, the partial pressure of water is much lower than 1 atm, therefore gaseous water can exist at temperatures much lower than 100 °C (212 °F) (see water vapor and humidity)."
:happy:
The steam is forming from any water u have on the bonnet or underneath as its gets very hot from the location of the turbo, i have it sumtimes, proberly nothing to worry bout
take a look on a wet tarmac when the sun is up in the springtime again. Same stuff different heat source. I believe I saw a Family Guy episode that mentioned this effect.. whats it called...:
-evaporation-
molecules collide dooood :)
this is a classic
next time stick a bit of salmon and veg on the bonnet, mmmmmmmmm lovely healthy steamed meal for 1
i get it off the windscreen a lot where the cold washer fluid evaporates against a hot screen
if it's not so bad ya can't see and it's above not below the bonnet i wouldn't worry :):)
