Strange boost problem...
Danny_B
324
Essex
Hi all,
I have a strange intermitant boost fault.
Car drives fine around town but after sitting at 70mph on the m25 for a little while it will only hit 5psi for ages.
It done it yesterday, then the EML came on and as soon as it did the car started fully boosting to 8-10psi (standard).
It must have logged a fault, hence the EML light but what do you guys think could be up?
It's an intermitant fault so can't be a pipe off somewhere.
I'm thinking N75 valve faulty?
Danny_B
324
Essex
Haven't got vag com but i will get it plugged into launch on monday which usually throws up the faults.
Just seing if anyone untill then lol
Danny_B
324
Essex
Plugged her in....
17536 - P1128 Bank 1 sporadic - mixture adaption too lean.
17658 - P1250 Fuel level too low.
I haven't ran the car low on fuel so don't get the 2nd one!
I cleared all codes and drove home.
On the drive home i had no power, think it was in limp mode.
I've disconnected the MAF sensor and it drove 100% straight away.
So it must be the MAF? How much do they cost roughly and will i harm anything driving with it disconnected?
Thanks,
Dan
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
sure its maf.... thought it would say 'G70 maf signal to low' ect... on vagcom, if so local seat/audi vw garage will have them, or local your local gsf cost 60-70 exchange....
Danny_B
324
Essex
It started going into limp mode after i done diagnostics.
Im sure it will have logged the maf fault now though.
Is it ok to drive with it disconnected?
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
not really advise to drive with it disconnected as it just guess's the air/fuel mixture so may run lean ect...leave it plugged in and it will be safe till you get a new one...
