dunno if it helps you or the others but if you need a spacer instead of double head gaskets just let me know - been getting some free nights for practice on a cnc/laser and water cutter so could do with the excuse to practice :)
plus as a bonus the brackets i've been making so far just so happen to be required on the hot rod :p
yeh it's up and running mate, only problem is that i have had to have the front hubs and bearings done and while that was happening the CV joint was shagged, went to change it and it had corroded onto the driveshaft, now trying to source a driveshaft :cry:
havent driven it in aboot 3 weeks, had it running for 2 weeks before that
what boost does your eaton produce?
std size pulleys?
thanks
B,
With that charger and engine spec, 10-11psi from 1500rpm to cutout. Pulleys are not STD. Designed around max engine revs and estimated compressor map from Eaton.
Any news?
I know it's kind of an old thread now but just wondered if you got it all sorted (driveshafts and that) and back on the road?
Wud be great to see some figures n see how it compares with my APK M45 chharged Golf MK4!
Cheers,
Toby
Cheers,
Toby
Im sure a company has it that does abit of dabbling in tuning, cant remember it off my head. Im sure they did bmw's and stuff.
It needs a bottom end and a few other bits and pieces to get it going properly and fixed.
thats my old car the company that bought it didnt have a clue and broke the whole car up gutted i sold it to them tw*ts for them to do that
