Diff will change everything! This will be one special car mate!
Keep it - Big Brakes and Big Turbo it!!!!
Haha, cheers mate!
I won't be going big turbo with this car but I may get bigger brakes one day, who knows..
Nope, no shortshifter. I quite like the feel of the gearbox as it is. It was starting to feel a little stiffer and slightly notchy when cold and I had to remove the battery to fit the Forge MAP sensor tube so did the gear linkage reset while I was at it.
It does feel a bit better than it did but mainly the "locations" of each gear feel a little more natural - like the line you push or pull the stick in to change just feels better. Tough one to describe, took a little getting used to but it just feels nicer.
Ahh coolio. I get what you mean mate. Mine is a bit notchy going into 1st from neutral, not sure if the short shifter just needs adjusting or whatever. It'll all be sorted soon anyway! Probably going to sell the gearbox that's on the car now once it's off and checked over.
