tdi coil overs
ibizadoyle
209
pembroke dock (wales)
hi guys got an fr 130 on coilovers and have been looking at some of the pics on here and my car is no where near as low i got mine nice and low but any lower and the tires rub at the slightest bump in road!!
in tips on how to go mega low??
thanks guys
simon
Feb 26, 2009
5,275
Wolverhampton
First question would be, what is it rubbing on? And why are they rubbing?
Are the wheels the correct offset? Or wider perhaps?
You should be able to get a bodyshop to modify the metalwork to allow the wheels more clearance.
The other thing is to reduce the suspension travel so that 'slightest bump' doesn't have quite an effect. Have the coilovers got adjustable damping?
Feb 26, 2009
5,275
Wolverhampton
In that case, remove the plastic arch liner! Just make sure you clean the arches whenever you clean the car, otherwise they'll get a load of crud on them and expose them to corrosion.
