I think just maybe put the pump on now it should still run better and wait for the code. Should be along soon as they are a large company, been going for years and have always supplied a good product.
Basically, the HPFP lifts the fuel delivery in the mid-range, The lower end and upper end of the rev range are largely unaffected.
But for example my car produces around an extra 40-50hp right across it's midrange than it did without the HPFP. As we know mid-range is where you spend most of your time anyway.
Therefore, like an intercooler, it does not actually increase performance......
hi mark,
can you (or awesomeanybody) clarify for me please.
as i understood it, the hpfp is a positive displacement pump, ie it will produce the same volume of fuel every rotation of the camshaft. this is obviously greater than the oem one.
adding a hpfp itself shouldnt increase the power of a car. the extra fuel it can deliver can only be utilised by a different map (opening injectors earlier/longer etc).
you did go stage 2 at the same time you replaced your fuel pump didnt you?
also, i cant remember you replcing you ic yet either have you?
i'd like to get these wrinkles ironed out in my mind as i think apr is the way i'm going to go.
The HPFP actually provides a higher volume of fuel rather than increase the pressure so to speak.
On a mapped car, 130 Bar may be requested from the pump by the ECU, but you might find less than 100 Bar is delivered by a standard pump at the point when high boost is requested.
Requested fuel pressure will be met by an uprated pump with no problems anywhere in the rev range.
.My car was used by Revo to develop the stage 2 code, and I've been trying to get a straight answer regarding 2+ for months now, now don't get me wrong here, I think that stage 2 is marvellous, but I was promised that if I fitted the HPFP, they'd use my car to develop 2+, but all I'm getting from Revo are evasive answers, 1st, oh we're busy developing the new 1.8 tsi code, fair enough, then the guy responsible was on holiday/in the states, ok, after many phone calls, I pm'd Kev, here's his reply:
"You haven't got an efficient intercooler on it though, the car was heatsoaking as it was... tuning on it isn't going to work as a stage2+ file will run the same as you have but more in the midrange meaning more heat. It would be fine to run on your car but tuning on it the car would suffer too much from heatsoak. To do a full Stage2+ file we need to use a car that has 'everything' on it so that the maximum potential can be attained. Then cars that aren't running all the components can run lower settings.
Thus why we need a car with an IC on as well."
The fact that my car was heatsoaking was never mentioned to me, either on the phone or when talking to Kev at the Inters, I can't afford a twintercooler, or an S3 i/c, so I'm left a little bit disappointed by all of this, if this had been mentioned at the Inters, then I might have been able to raise some extra funds, but now, hmmm....
He also told me that they've got a misfire on stage 1 08 Cupras, but not 07 Cupras, weird...
It's on my to do list to, trouble is lack of funds, gonna have to sell a few things before buying a new I/C![]()
What prices have you been quoted for the S3 core out of interest?
