Weird similarities going on here..
Mind grinded into second the other day, then was unable to put into 1st right after? However soon after pulling away in 2nd and then using all the gears 1st was fine...
However sometimes it doesn't go right into the 1st gear easily...
Mine does the same when cold, although it never grinds or anything. It just doesn't quite go into gear, you have to put it back in neutral, de-clutch and then try again. Also does the same in reverse sometimes.However sometimes it doesn't go right into the 1st gear easily...
There's no real requirement to change them all, it's only the rear wishbone bushes that are a voided bush (and therefore they break!), all the others are much more solid. I would recommend doing the ARB bushes as well but it's important that the garage check the collars on the ARB for corrosion. If the collars are corroded there will be play in the ARB, which causes a knocking noise.also after speaking to a mecanic last night he said it might be best to replace all the bushes to uprated ones just incase they are all in the same state as the screwed bush...whats your opinon? change all of them or leave them?
if i do change all of them (which i am thinking of doing for piece of mind) what ones do i need to change? I know the ARB bushes are ones that would need changing
How did your A level results go guys? Assuming you're still in college.
My gearbox is exactly the same! was going to try and change gear box oil but had an hard time so gave up!
Have you applied to any Uni's? I got results for 9 exams today....January nearly killed me
Need to somehow get ABB to get into Manchester Uni for Economics :'/
Haha noooo UWE is my insurance Uni.
I've applied to Manchester so need ABB.
Out of the 9 exams I had 6 retakes...a couple of which I had taken three times. Got AAAAAB in retakes then BCD in my A2's so not so well :/
Ah well done for your results mate! Glad I'm not the only one doing GCSE'S and work at Waitrose who drives an Ibiza![]()
GCSE's? So 2 years ago
A levels mate![]()
What degree did you apply for?
Can't wait to see my pay cheque, done lots of overtime this month as well![]()
