josh_28
would subaru legacy alloys fit on my ibiza as everything is correct (studs and PCD and offset and there 17"s which im after) but there are people saying the centre bore is different and people saying it isnt?
can anyone give a definite answer?
had link to the wheels but i need to have 15 posts first and just joined
cheers
Legacy wheels need adapters..... but anything fits with adapters ;)
Centre bore is too small, soz mate. Welcome to the site by the way
what adapters will i need like as surely it will space them to far out arches?
Legacy wheels are 5x100 and fit if you take the centre bore out, I think 4mm. Ibiza are 57.1, if I remember correctly Subaru are 53.1. Adaptors aren't needed its the centre bore that needs milling out.
Offset is high (around 55mm) so some 10mm spacers would be a good idea to bring it down to Ibiza levels. 20mm would look better ;) Just make sure they are hub centric!
I could be wrong on PCD (could be poss 5x114.3 on later models) but as a guide Ibiza are definitely 5x100 and 57.1mm centre bore
so what your saying is just space them past the spigot on hub so they fit and 10mm would be minimum?
lol i know engines and everything else on car but ****ing wheel offsets and spacing i never learned haha i am a machinist/mechanical fitter by trade so if i get a bit of time free might make the spacers.. but due to lazyness and the two projects on go just buy them haha
Here's my subaru prodrive alloys.
Fill the arch better but the centre bore is bigger so I need spiggot rings from 57.1 to 73 I think it is
