Mar 13, 2019
since putting a de-cat on my gas pedal stopped working and car came up with the following faults
18039 accelerator position sensor (g79) signal too high
18042 accelerator position sensor 2 (g185) signal too high
17581 angle sensor 2 for throttle actuator (g188) signal too high
17987 throttle actuator (j338) adaptation not started
so i was told to change the pedal done that no change, then told to change the ecu done that worked for 6.5miles then same problem again, then told to clean throttle body no change also tried the spacer and nothing so have now put the car back to normal with the original ecu but still nothing im now pulling my hair out please :help: me
