if i were you just hybrid your current k04 turbo. speak to backdraft motorsport for this.
they are a sponser of this site
Won't a k04 hybrid kill my rods definitely ?:confused:
Because of the strut, it seems as nobody else is interested, start ordering one piece ? :D
Hi mates
if i go on reading the board, i start thinking, that the k03 hybrid would have been the better alternative for me , than using the k04:(
I got some questions, maybe somebody can answer them :)
Do i need a normal k03 or a k03s for building an upgrade hybride out of this ? Is there a difference between k03 hybrid and k03s hybrid ?
I believe there is not much difference when you hybrid them both, if any at all as the main difference between the standard turbos is that the K03s has 8 blades and lighter internals than the K03 12 blades. When they are made hybrid these are stripped out for new ones.
I will be corrected if I'm wrong.
Very nice Tobi, sounds like you don't cut any corners and look after her well! Is the cupra a rare car to see in Germany?
Oh and how do you fancy swapping your passenger side wing mirror for my drivers side wing mirror...!?? ;)
is there a easy english version availabale.. dont really understand everything :( i'm sorry. You wanna change mirrors ?!!?! :)
The strut will be about 95€ + shipping. Today my secondary air system was disabled by my programmer , no more errors !!yeah!!
Tomorrow i'll remove the **** n249 and the cables and the battery will be mounted in the exchange wheel basin. More space for my air filter and the new pipes of the intercooler.
Best regards, Tobi
Sorry I meant you put a lot of effort and care into your car! If we swapped mirrors we would have even sizes both sides!
yes, youre right. In Germany the ibiza is really rare, thats a pity :(. Mirror change, hm i'd prefer the bigger ones, i hate these small nupsys. Let's change :D
Tobi
Best regards, Tobi
Hey tobi my management light has been on due to the secondary air system & i would love to know where about in the ecu u woudl go to disable this error? I u could find out from ur programmer this would be great....
So, update:
Today i made some logs, the maximum airflow in g/sec was 187. Do you think that is okay for an K04 ? My programmer is still on holidays :/
Regards, Tobi
So, today i called my programmer, ill go on for a new software. Before i have to change:
* FMIC into 60mm , that means no more Forge
*76mm Downpipe. In Germany nearly unpayable, i found this on ebay.co.uk KLICK
Anybody some experience with this downpipe ? Can you give me an advice, which downpipe would suit ?
Thanks, Tobi
So mates, a lot of things done :)
First of all, i detached my intake brdige, because i want to renew all the gaskets and replace the oem hoses by siliconhoses. Then ill take my Forge007 directly to the throttle.
Here the bridge after i grinded it about two hours :) :
Than i wanted to make the base of the bridge black, because you cant really see it, because of the fuel hoses und fuelvalves above it:
After i painted it several times, it was very shiny
okay, the separation between polished and painted could be a little bit better, but you cant see this later, so , doessn't matter :)
Then i did the same game with mit throttle:
dirty and unloved :)
becomes shiny and loved like this one
--- i need a post ----
So, the colour was still not empty i started grinding the valve cap:
And after some time (nearly two hours) i painted it :
I'm really proud on this one, cause all my mates said : don't do this, won't work... this won't be clean enough for painting blaaa blaaa :p handmade original is still the best
For my new pipes in 60mm and the new FMIC i had to create some space on the left front. There has been the horn and the thief signal. I took them to another position, here you can see:
After that, package arrived, my hoodlift :funk: directly mounted:
okay, this isn't the best picture ever :)
and last but not least, the mounted FMIC (only mounted on one side, other side is cable )
I really like this one and i'm very sure, i wont miss my "diameter swithcing from small to too small, edge insted of curve and so on" Forge FMIC :)
I hope you understand my english :)
Regards from Germany at 30 degree celsius :p
Your car looks excellent, the wheels really suit it :D
Have you got any pictures of your engine bay now you have painted the valve cover and inlet manifold?
Im trying to find out where the data is that i need ammened, Can anyone help?
I can give you the adress from the programmer, that made this for my car: www.tij-power.de
Actually i still have some problems with the holders for the valves in the intake manifold :( i hate this **** :(
Bye
