Top small diy mods????
BIGGER TURBO ON LC WORTH IT?
  • Total voters
    22
inch0408
LEON LOVER
Jan 28, 2013
62
GLOUCESTERSHIRE
RIGHT FOLKS I HAVE A LC ONLY 180 BHP ATM :( DECAT FITTED, SAMCO TIP, 007P, OPEN CONE, N249 BYPASS.
IM LOOKING TOP GO STAGE TWO WITH FMIC ( WHEN I CAN AFFORD ONE) AND 4BAR FPR AND HYDRO METH. I LOVE THE N249 BYPASS AS IT GETS YOU OILY AND IN TOUCH WITH YOUR ENGINE.
SO WHAT OTHER SMALL BUT BENEFICIAL MODS CAN U RECOMMEND WHILST IM SAVING FOR FMIC AND B4 MAPPING?:headhurt:
James D1
Pre-facelift
Aug 2, 2012
255
Essex, Uk
dogbone mount, allows you to put some of your newly acquired power onto the floor. total cost of £40 if you fit it yourself.
might be worth fitting a catch can and doing pvc removal, as pipes on these are crud and probably will perish later on.
inch0408
LEON LOVER
Jan 28, 2013
62
GLOUCESTERSHIRE
Yea i really want to fit a catch can but there is soo much conflicting stuff on here, 19mm cans are expensive but is it ok to use 15mm? What exactly is the pcv, and do i vent to air and block the tip? Do i remove the hockey puck? And blocking brake breathers???? Really need help with this one
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
You need to do so reading and decide which set up you want.
inch0408
LEON LOVER
Jan 28, 2013
62
GLOUCESTERSHIRE
Ive read loads on here about catch cans and pcv but no1 seems to know or the convo goes off topic or all the info conflicts so it uber confising to lnow whats best.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Cheap decat
Panel filter
Fmic
And you should see 240bhp! Wouldnt bother with a bigger turbo
jacoblongman
Take the spare wheel out you'll be surprised how much it weighs!
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
You're talking about big turbo but then scrimping on things that are crucial to get right. Save up the extra and get the right thing for the car. :)
