Turning Custom code on/off
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Right strange one this...
Just been out in the car and decided to swap the map back to the normal one,
First off the code read 20005, i changed the 2 for a 0 and went out, the car seemed the same as usual, i swapped back to 20005 and still though they were both similar... any how i decided to change the map to 10005 but when i went to recode the code read 00140???
i changed back to 20005 and left it,
Why will it have changed and why did the map seem/feel the same??? Was i doing it wrong?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
when u first changed the code the first time did u click do it , exitted vagcom and turn the car off , then restarted
performance mode is 1 as well or do u have 2 performance programs
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
I reckon the car only has one map on it...
i clicked "do it" then it read 00005 and off i went, didnt turn the car off and on again tho???
Should i do that?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
when i turn mine off n on , once i click "do it" the screen refreshes and i get silly numbers , some blocks read 000 and others get range of different numbers , u exit vagcom and restart the car ,
your changing the correct number ,yes ???
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
just been out again... turned car on/off
Job done, back to normal map...
Im just gonna drive about for a few days with the standard map on, then switch it back and hey presto a remap all over agian!!!!!
i might do some acceleration logging aswell, if i get the time,
Cheers for the help mate.
