• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
queen
~Nassia~
Nov 29, 2010
735
98
Athens, Greece
Hello everyone, need some help deciding if it's worth fitting this: https://www.racingline.com/mqb-underbody-brace
As it says on the website it improves handling and provides extra clearance for an aftermarket exhaust. I have a milltek gpf-back fitted and sometimes it used to rub on the stock rear tunnel brace. It was solved by fitting nuts where the brace mounts and that provided some extra clearance about 0.5cm.
So two questions,
1. For road and some light track use is it worth it? Will there be any noticeable improvement over the stock ones?
2. Does the solution my mechanic came up with has any negative effect on handling?
Car is now stage 2 and will be stage 3~500hp and 600+Nm within a year.
I doubt it will be noticeable at all
However will clear larger exhaust. I mean if you want to purchase it then that is also fine.
I wouldnt lose any sleep over the decision
Reactions: queen
