having read this most people seem to have there them guage reading 90 mine constantly reads below 90 just on the left hand mark about 75 i would guess? is this wrong?
cheers chris
cheers chris
Pretty sure the needle should sit constantly at 90 - it did on my old LC and on my current car until they both developed the same problem.
This is properly confusing! So if the gauge can only get a signal from the green top sender, and I've replaced that with a brand new OEM one - why would the gauge still be wandering? Struggling to see where the thermostat comes in :confused:.
And I'm assuming the climate control display gets the same signal as the one that's being sent to the ECU - which is a constant 90 so in theory the only problem I have is an annoying gauge.
A new twist
After paying a bit more attention to when the needle drops, I've noticed it's not just a random thing - it only drops when I'm going downhill:confused:
Now I could understand if the gauge was related to coolant level in the same way the fuel gauge changes depending on the road gradient - but as far as I know it's not!
Had no other problems so for the tme being I'm not too worried, just annoyed by not knowing what's going on!! Any ideas?:shrug:
But why would the needle only drop going downhill? I wouldn't have thought a faulty thermostat would be so 'predictable' as it were:shrug:
My water temp gauge drops from 90 to about 65 when I boot it.........could this be faulty sensor as the incresed air flow wont make that much difference?
If so I replace with a green one?
Normally coasting (in gear) or very light throttle
Yeah thermostat still gets my vote as it's not holding temp when coasting.
Easy enough to do
http://www.seatcupra.net/forums/showthread.php?t=210977&highlight=thermostat
Yeah replace with a green one.
I not sure what colour it is mate I not even looked.
I'll get one off ebay in a min...sure I seen green ones on there pretty cheap :)
