Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Don't forget what's in the J794 module.
Here's what's in mine when I did a scan.
<CODE>
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5F0 035 858 A HW: 5F0 035 858 A
Component: MU-S-ND-ER 040 0407
Serial number: E5F00506132498
Coding: 04730001FF0A000021111101000800002F0101060100010046
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE_SE37.rod
VCID: 29591B2F480CF956E3D-807C
Media Player Position 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0020
Serial number: SEZ8Z9N5600NSR
Engine Control Module 2:
Subsystem 2 - Part No SW: 5F0 919 866 C HW: -----------
Component: ECE 2013 --- 0021
Serial number: --------------------
No fault code found.
</CODE>
This matches what the SavNav sees when the SD Card is installed.
"Navigation database: 5F0919866C 0021 ECE 2013". See Setup / System Information on the Media System Plus.
From what I understood there is nothing you can do unless you pay for the updates.
And lastly, 195 EUR for a single update is plain ridiculous.
P.S. I agree 150 EUR is not that much for free updates for three years and I am ready to pay that to SEAT if they can retrofit it to my Leon. If not, I am more inclined to do some hacking rather than pay 195 EUR for each update.
This topic actually leads me to another guestion regarding SD cards. I know this is off the topic but does anybody know what is the maximum size of SD card that Leon MK3 accepts? I know that 64 GB should be ok, but what about 128 GB? Has anybody tried out?
True, unless you are dedicated hacker with tools and knowledge. Risk is that you ruin that original SD card of yours.
My opinion is that 130-150 EUR is not that much money if you consider that it offers three years of updates. It is also very little money compared to what the car costs. You have to value your personal time somehow as well. If you spend hours and hours for this thing... is it really worth it?
Looks easy enough. Does it work?![]()
Ok guess someone needs to find out how to activate map care then?
"Do not rewrite on the original SD card if you are not absolutely sure that you have the MapCare service!
Rewriting the SD card without hiring the MapCare service may cause data loss!"
Seems that are friends over on a Dutch forum have this working fine with mapcare. Just need somebody who can speak Dutch to ask them if its possible to switch on mapcare with VCDS, or what their dealer did to enable it.
