Yes you have a Mib2 standard unit that's defined by the 6P.
https://hereshop.navigation.com/pro...GBP;pgid=SnxSvdWt6lFSRpN7zhogxO2o0000zQU8u0Gv
The latest Maps are 2018 code 0915 but there will be the 2018 / 2019 in six weeks time or so if they come out to schedule. You can jump straight to that release if you have the 6P MIB2 system.
Take the copy from the Seat site
http://www.navigation.com/is-bin/IN...me_campaign_light&&Page=VW_Europe_Media_MIB2&
Or direct from here
http://vw-mapscdn.tdd.adacorcdn.com/0915_MP171-1284.xEUR1.7z
Look at post 948 and 950.
Basically take a complete copy of the existing map card (Not an image copy), just the normal one onto your HD, files and directories. That's your fail safe. Then delete what's on the SD card. Unzip the download onto it with the same directory structure using 7zip. Then copy back that all important file from your HD as defined by stage 3
https://forums.seatcupra.net/index.php?threads/navigation-system-updates.388586/page-31#post-4731938
You don't need the original step 4, but you do need step 3 !. It should work.
Full credit goes to Notabenem for the steps... I justed edited them down into this below:
xxxx old version
yyyy new version
0. Take a complete back up of the existing map card to the hard disk
1. Reformat the SD card that had xxxx on it
2. Copy the freshly dowloaded yyyy version to the SD card (with 7zip preferably to unpack) same file structure needs to be kept, not one down etc.
3. Replace /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with old one from your HD backup
Should be fine. Bearing in mine I got a Plus unit I've never done this process myself but know how it works
. You might get away with using Windows zip unpack but if there are issues use 7zip.
